Hot!2008 420 honda fuel lags
Lilmouse916
2017/03/14 21:29:57 (permalink)
New to the here but I have read a lot on here over the past few years but I haven't been able to find any thing on my problem now I have a 2008 420 honda i got it in 2010 and its all ways had a bit of a lag off idel from a dead stop when if u get in on it hard it's like it takes a few seconds to take off a friend of mine has a 2009 and his does not have that problum i have changed fuel pump and filter and injector and cleaned fuel lines but didn't helped and I just rebuilt it 2 weeks ago and put dynatek fi controller and big fun exhaust i have tried different spark plugs I'm runing ngk now going off the plug it looks to be burning off like it should any help would be great
9 Replies Related Threads
    Re: 2008 420 honda fuel lags 2017/03/14 22:14:59 (permalink)
    Factory air filter? Clean air filter?
    Lilmouse916
    Re: 2008 420 honda fuel lags 2017/03/15 07:10:49 (permalink)
    K&n and its new just put it in
    Re: 2008 420 honda fuel lags 2017/03/15 07:14:50 (permalink)
    I wonder if the initial spray is to much which causes it to bog for a bit till it burns off? I'm gonna have to think about this a bit.
    Lilmouse916
    Re: 2008 420 honda fuel lags 2017/03/15 07:15:54 (permalink)
    Re: 2008 420 honda fuel lags 2017/03/15 08:53:02 (permalink)
    I think your problem may be the map sensor. The sensor reads the air flow and tells the system how much fuel to spray to make the proper mixture. If not the sensor it's the mapping in the ecu as the curve for idle to 1/4 throttle is off. Also do you have a snorkel?
    Lilmouse916
    Re: 2008 420 honda fuel lags 2017/03/15 11:29:10 (permalink)
    Yes but it done it b4 snorkel
    Re: 2008 420 honda fuel lags 2017/03/15 12:56:46 (permalink)
    I still think it's mass air flow sensor or ecu programming issue. The snorkel will also ad to the problem but the programmer should have taken care of the added air from the snorkel.
    Lilmouse916
    Re: 2008 420 honda fuel lags 2017/03/15 18:02:26 (permalink)
    A buddy of mine has a 09 420 I might try to swap parts and see if it helps
    Re: 2008 420 honda fuel lags 2017/03/15 19:16:44 (permalink)
    It's worth a try but not sure if the ECU's will crossover.
