DustyFontenot
Total Posts
53
Reward points
2007 chevy towing 5 atvs 5 hours to mud nats?
Wednesday, March 10, 2010 11:47 AM
( #1 )
i have a 2007 chevy silverado z71 (new body) 5.3. do yall think i would be ok hauling 5 atvs on a 20 ft trailor 5v hours to mud nationals taking it easy?? i also have 33" toyos with 20s on it..
2002 foreman 450 ES 28" outlaws 2" lift HL springs 14% gear reduction clutch kit snorkel paddle HMF pipe
onebadrubi
Total Posts
5221
Reward points
Re:2007 chevy towing 5 atvs 5 hours to mud nats?
Wednesday, March 10, 2010 12:09 PM
( #2 )
It is a load for sure but its not out of the capable towing range of that truck. Sadly you probably dont even have 3.73 gears so it might feel luggish. If the trailer has brakes I would attempt it. Things to try/look out for -Load the lightest possible weight on the tongue, heaviest and equipment on trailer axles - Accelerate without getting into OD untill you are able to maintain that speed, you dont want your transmission constantly locking/unlocking the torque converter and going into OD, this will lead to excess heat in the transmission. - constantly watch tranny temp - truck will like to pull around 2200-2500 rpms -check all tire pressures, you can add some to the rear tires to stiffen them up. Toyo's have a high air pressure rating which will be good for this. also check trailer tire pressure and make sure those are correct to what the tire says.
DustyFontenot
Total Posts
53
Reward points
Wednesday, March 10, 2010 12:20 PM
( #3 )
yea the trailor has brakes n i have trailor brake control thing in my truck. i though about about buying a superchip or programmer but i think im going to be okay..and we have 4 honda and 1 brute so they not no real heavy bikes
joseph9936
Total Posts
165
Reward points
Wednesday, March 10, 2010 12:42 PM
( #4 )
I have a 16' foot trailer and I carry 4 on mine. Like everyone said it is a load and watch what you are doing but it really looks cool behind my 4 door jeep rubicon.
georgiaboyskingquad
Total Posts
702
Reward points
Wednesday, March 10, 2010 1:34 PM
( #5 )
z71's come standard with 3.73 gears... its part of the package. you can special order them with a different ratio, but most dont. you should be plenty fine. if you have tow/hual mode, use it. also, keep it out of overdrive when driving through town or slower than 55mph... hauling a heavy load while the tranny is in overdrive will cuase alot of heat which is bad for transmissions.
<message edited by georgiaboyskingquad on Wednesday, March 10, 2010 1:35 PM>
let_it_be_known
Total Posts
1756
Reward points
Wednesday, March 10, 2010 1:39 PM
( #6 )
Like many have mentioned.. Watch your parameters.. It is a load but you will be fine. I used to pull 4 with my Z on 35s and it was a load. Now i stepped up to a Duramax and glad i did!
2008 Black RZR- 30" Mudlites, 14" SS-112s, 3" Extreme lift, Green lights, One loud **** stereo!! 2005 Black Scorpion Lined POLARIS 800 EFI 6" Gorilla. Dirty-Deuces 2008 Black GMC CCSB DURAMAX FULLY LOADED.. 6" BDS, 35" Toyos on 20" Incubus Poltergeist. 2008 Pink Sportsman 90 ~ Daughter's
Barras22
Total Posts
613
Reward points
Wednesday, March 10, 2010 1:57 PM
( #7 )
Z71s do NOT come stnadard with 3.73s...i have seen plenty with 3.42s which is GM gear of choice for some reason! Just dont pass up a gas station and take it easy and you should be fine. May even run with it in 3rd gear depending on what rear you have.
back2XR
Total Posts
631
Reward points
Wednesday, March 10, 2010 3:51 PM
( #8 )
You will be fine. My father truck has towed just like that since new. 2001 sierra 1500 5.3. We vacation 7 hours away, that truck has made many many trips. He has over 80k miles on it, and its not his dailey driver, probably half those miles are towing between 5-6k pounds. Like said above, tow haul, take it easy, and watch your temps, specifically your tranny temp. Try to keep your momentum and avoid stopping and starting. You will be fine.
-07 Kawasaki Brute Force 750i, Dynatec CDI, two needle shims, 26x9-12 Big Horns front/rear, ITP C-7 Rims, Hand/ thumb warmers, Tusk atv handgaurds, Black Viper 2500 Max(aka classic) w/ amsteel, yukon backrest, Black and Decker tool box, truck mudflaps
974door
Total Posts
542
Reward points
Wednesday, March 10, 2010 5:57 PM
( #9 )
I have an 08 lowered on 24's. I pulled my 28' travel trailor with a utility trailor behind it with my Teryx on it all the way to the dunes last year. Did fine. Put the edge programmer on it and made the same trip, did even better. So to answer your question, you will be ok.
08' Teryx FMF slip-on exhaust Quad Shop Custom clutch kit Red primary spring Xtreme Lift on 29.5" Swamplites Enough audio to bring the hood to the woods
Total Posts
31809
Reward points
Wednesday, March 10, 2010 8:20 PM
( #10 )
lol yeah when i bought my 06 Z71 every Z71 on the lot had 3:42s in it and the other dealer i had been to early in the week was the same way 15 or so Z71s and every one with 3:42s, stupid IMO but they where doing it for the MPG numbers.
Xtreme Missouri Boyz Finding the Holes and Rooting them Out.... 08 650H1 LE 30" Silver Backs on ITP 212s Gorilla Axles, 1.5" lift, Rad racked HL 1" & 1.5" wheels spacers, HL springs on popo shocks Dual 3" snorkels, Dyno jet kit, DynaTech CDI Fully clutched, Red EPI, 19gram rollers, 42# springs, fix plated modded Modded Stock pipe,4.0s & a Skull Head shift Knob..lol 05 500H1m LE 29.5" Laws on ITP type 7s Ride in springs & HL springs in back Dual 2" snorkels, Dyno jet kit and 4* timing key SpeedWerx 42# springs and a SpeedWerx Pipe. Viper 3000 Winch & a Skull Head shift kno
gmcz71
Total Posts
15636
Reward points
Wednesday, March 10, 2010 9:16 PM
( #11 )
the GU6 code (3.42 gears) were used again starting in 03 or 05 for fuel mileage savings. same time rear dums were swapped in. 99-02 Z71's come with the GT4 (3.73's) and will pull a little better but have less HP than the newer models. seems like a stock truck with 3.42's and 33's isnt gonna like any load at all but if you have the towint package with trans cooler, that will help limit the amount of damage being done to your trans. Id use tow/haul on flat surfaces and manually shift to 3rd when a hill approaches.
Total Posts
31809
Reward points
Wednesday, March 10, 2010 9:25 PM
( #12 )
with that many quads on the trailer he will have to use 3rd all the way for sure. with mine 2 quads is the limit and a light weight trailer if i load 3 quads mine wont stay in overdrive if i want it to unless its flat ground or down hill...lol 3;42 just dont pull well.
Expat_Dude
Total Posts
2121
Reward points
Wednesday, March 10, 2010 9:29 PM
( #13 )
Make sure all of your maintenance is up to date (ie fluids etc)... As the others mentioned just take it easy and you should be ok..
Pro Staff Member 2010 Popo 800 Green (his), 2500# winch, 28 Radial Laws on 14" Chrome XL2's 2010 Popo 800 Red (hers), 2500# winch 2008 Raptor-- GTYR Lid and Slip on exhaust Other toy-- 68 Camaro SS My Pics
onebadrubi
Total Posts
5221
Reward points
Wednesday, March 10, 2010 10:16 PM
( #14 )
GWC did you never regear?
Total Posts
31809
Reward points
Thursday, March 11, 2010 5:45 PM
( #15 )
nah money has been tight and the truck is on the back burner, So iam still putting up with this guttless pile of mine...lol TM and 3:42s really suck bad to try to pull anything or even to spin a tire on wet pavement...lol really a shame it has what right around 300hp and i dont get to use but what like 100hp or so..LOL
KOD4x4
Total Posts
881
Reward points
Thursday, March 11, 2010 6:22 PM
( #16 )
 5 wheelers would weigh tops 5k plus your trailer so I would say you should be fine w/5.3. My Baja weighs 6500ish (loaded up and on trailer) and my 5.4 doesnt mind...
2010 Polaris "Stealth" 850 XP EPS - 31x11-14 Outlaws, 14X7 MSA Diesels, 3" SLC Lift w/Rake, Clutch Kit, SLD Mod, Gear Reduction Kit, ATV-Guru Front and Rear Bumpers, Front Lock & Ride Box, Triangle ATV SnorKit w/Kenwood Radio and (4) RF 8's, Dual Batteries, Triangle ATV Rack Plate w/Back Rest, Ammo Cans, and Cooler. 2011 Ford F-250 Crew Cab FX4 6.7L - Limo'd, Pioneer Z110BT, Recon smoke mirror, clear cab and clear 3rd brake lights, more coming... 2005 Baja H2X - Jus a few Wet Sounds Speakers and JL Amps...
DustyFontenot
Total Posts
53
Reward points
Thursday, March 11, 2010 6:29 PM
( #17 )
Thanks for all comments. hey GWC whats TM? ive seen that alot.. and anybody know how to tell if i have 3.42 or 3.73 gears??
gmcz71
Total Posts
15636
Reward points
Thursday, March 11, 2010 11:36 PM
( #18 )
Torque management an anti abuse software for the trans. in your glovebox... GU6 = 3.42 / GT4 = 3.73
Polaris_for_life
Total Posts
1655
Reward points
Friday, March 12, 2010 3:44 AM
( #19 )
joseph9936 I have a 16' foot trailer and I carry 4 on mine. Like everyone said it is a load and watch what you are doing but it really looks cool behind my 4 door jeep rubicon. Not smart at all, When the rubicon only has a 3500 # towing. Jeep's arnt meant for towing.
2008 Polaris Sportsman 500 28-8-12 28-12-12 Mudzilla's K&N A.K.A The Volks Waggen My babies: Stihl ms 361 Stihl BR600 Support every Man and Woman fighting to keep us safe, from Firefighters/EMT's to the tropps your all heros. R.I.P Brandon Paudert and bill evans, and every other hero that has fallen. aim/msn= Caleb1994@luckymail.com For both.
DustyFontenot
Total Posts
53
Reward points
Friday, March 12, 2010 6:29 PM
( #20 )
i have the 3.73 gears and i found a superchip for a good price so that should do it for the long *** haul
joshua99ta
Total Posts
4851
Reward points
Friday, March 12, 2010 7:04 PM
( #21 )
I'de let er eat! ... but thats just me
Team Outta Kontrol Little Bit of Wild Boar Love Thrown In The Mix I'M JUST HONEST... www.myspace.com/joshua99ta DWH 11 LOST BUT NEVER FORGOTTEN
onebadrubi
Total Posts
5221
Reward points
Friday, March 12, 2010 7:47 PM
( #22 )
50$ is a waist on a superchips, so I hope a good deal means please come get this crap off my hands for FREE! Superchips at any price on these trucks is junk!
#1rubicon
Total Posts
2383
Reward points
Friday, March 12, 2010 9:32 PM
( #23 )
go for it, we've hauled 5 with our z countless times
waldo
Total Posts
531
Reward points
Monday, March 15, 2010 8:46 AM
( #24 )
run it in 3rd and let er eat ive pulled 5 behind my crewcab z w 33s and 3.42s without a problem and have pulled way more than that with it yes she is a little sluggish out of the hole but on the highway you want have any problems
mine 08 650 outlander 30" mud lites custom lrd exhaust pod mounted snorks hers 07 rancher 400at 25" super swampers custom exhaust snorkled
02Sleeper
Total Posts
2959
Reward points
Tuesday, March 16, 2010 10:00 PM
( #25 )
I tow my 7500lb travel trailer with mine. I have 3:42 gears and 33's also. I do have a cold air intake, programe PCM, dual exhaust, big trans cooler etc..... I put it in 3 rd and stay there. At about 2500 RPMS th truck is happy. Below that and it really struggles. Furthest I have towed it about 200 miles. I also tow my 30 flatbed with my Ranger crew (2500 lb pig lol) and two full size ATVs with less effort. So what I am saying is you will be fine if you use 3rd and take it easy.
2010 Polaris Ranger Crew LE Snorkled belts, 28" Laws, Custom roof, A few 6x9's lol, A few Leds, PA system 2008 Red Rhino 700, Snorkled, 28" Laws, Itty Bitty Stereo lol A couple of LEDS etc... ( sold) 2004 Honda 450S Snorkle, 27" Bi-tri comb Gear reduction, HMF Perfex lift, HLsprings, leak shield, Full alum skids Bumpers, disk brakes etc.... 2003 Kodiak 450 HMF, Snorkled, 28" Laws " The constution says promote general welfare, not provide welfare" Lt. Col. Allen West
4fifty
Total Posts
225
Reward points
Wednesday, March 17, 2010 4:25 PM
( #26 )
hook it and go!
southern86
Total Posts
334
Reward points
Wednesday, March 31, 2010 9:27 PM
( #27 )
Yea 3.42 suck so Im switching mine to 4.56 and putting 35's just did some motor work and cant wait to see the new towing performance
2007 420 Rancher 4X4 Snorkel by LOUISIANA PERFORMANCE LLC. Hmf Utility Series PCIII Comp Clutch kit 28" ZILLAS 14" ITP SS 312 OUTLAW CLUTCH KIT FOR SALE $50
