2006 grizzly 660
Cwebb88
2017/04/03 20:24:36 (permalink)
2006 grizzly 660
I have a 06 grizzly that blows ignition fuse every time. I notice my lights dont work anymore as well. Kinda leaning towards a cdi. Was just going down trail and quad died lights quit working the ignition fuse blew. The center plug was very hot and started smoking. I unplugged the top and bottom plug and fuse would not blow. Soon I put in middle one it popped. Also push button don't work anymore. Would that have anything to do the cdi.?
3 Replies Related Threads
    Re: 2006 grizzly 660 2017/04/04 06:45:08 (permalink)
    Good possibility. I'd check and make sure I don't have any loose or skint wires that or putting some extra resistance on the electrical system. Check all your grounds for sure. If all that looks good then I'd say CDI.
    500mfarmer
    Re: 2006 grizzly 660 2017/04/04 09:45:38 (permalink)
    I agree double check all wires for rubbing. I had that problem with my cat. Was a wire rubbed through loom and very hard to find. maybe search common wiring rub spots to narrow it down and start there?
    Dezz
    Re: 2006 grizzly 660 2017/04/04 17:29:40 (permalink)
    Your problem is more than likely in your wiring harness. More specifically chafing in the harness.
    Remove the gas tank to get the best access to the harness. Pay particular attention to wires running near the exhaust and where they run up the steering stem. These are the most prone areas for chafing.
    2003 Yamaha Grizzly 660
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    - SOLD - But not Forgotten
    1998 Grizzly 600
    ITP Delta Black Chrome Rims
    4 - Kodiak 450 Clutch weights
    Uni Air Filter
    Warn A2000 Winch
    Oxlite CV joint protectors
