Hot!2005 grizzly 660 no crank issue?
acott207@gmail.com
2019/12/19 17:09:05 (permalink)
ok guys pulling my hair out here baike ran fine no issues till it was rolled not by me long story. bike sat for two years due to it not running after being rolled. rebuilt no i hace a no crank issue. no its not the battery or starter solenoid, and the starter are all good. if i jump out the solenoid it will start and run fine. here what i have power to dash transimision signal lights work fine break levers all turn on break light. all fuses are good. here is what i have found i am not getting power to the coil on the solenoid to energize it. if i jump this out with a hot wire blue wire with white strip, jumper to positive on battery and leave hooked up when i hit the start button it will vrank and fire everything seems fine except if left that way when ever you hit start button it will crank key on or off any help. i believe this wire goes back to the cdi box
1 Reply Related Threads
    Re: 2005 grizzly 660 no crank issue? 2019/12/22 20:11:53 (permalink)
    You probably have a broke wire or burnt fuse somewhere. So trace the wires and or do a continuity check to make sure the wire is good.
