Locked2002 honda 4x4 350 rancher carb problems
Whitebandit
2010/03/22 20:01:52 (permalink)
Ive had problems for a while now with my carb. Ive rebuilt it and cleaned it and its over flowing gas out of the over flow tube. I tookk it apart and made sure the float was working and stopping the gas flow and it will until I put it back together and it does it again. Do you think I need another carb or Im I missing something?
  Team Carnage
If it's Cheap and Reliable, it's not Fast.....If it's Fast and Cheap, it's not Reliable.....If it's Reliable and Fast, it's not Cheap!!!
if it ain't broke.. keep fixing on it!
2012 Teryx 4. 30in monsters on black 14hd's
If you voted for Obama to prove your not racist- Who are you going to vote for to prove your not an idiot?
13 Replies Related Threads
    Bock
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/22 20:07:46 (permalink)
    my buddie had that prob is the tube on the bottom still there it has a one way valve on it
    09 HONDA FOREMEN 500
    warn winch
    29.5/10 laws
    SS108 Machined Alum
    HMF
    Dynojet Kit
    Snorkeled
    2in lift in the front
    450 swingarm swap
    clutch kit
    FLAT BROKE OFFROAD
    SPRING TX
    CO-FOUNDER
    Whitebandit
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/22 20:15:27 (permalink)
    Bock
    Im not sure what your asking but there is a tube still there and I have a rubber tubing on it to drain to the back in of the 4 wheeler
      Team Carnage
    Whitebandit
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/22 21:26:06 (permalink)
    Anyone?
      Team Carnage
    Whitebandit
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/23 13:50:31 (permalink)
    Im guessing no one has had this problem before?
      Team Carnage
    redsoxrincon
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/23 20:16:44 (permalink)
    can't remember but i think that float is plastic...well...even though u took it apart...and u moved your float to make sure it cuts the gas on and off...doesn't mean the float is good....and sometimes u have to take your float off and shake it...b/c if it has gas in it...sometimes u really have to look to find that out....and truethfully...that sounds to me like it could be a very likely cause.....if ur flow needle works....then...only way it could do this is to flood or simply drain....trying to make things idiot proof is not always the best thing either...so back to the basics....double check your drain screw..make sure it is turned in the right way....
    Thunderstruck Racing #3 CATFISH
    2007 honda rinny
    28" Vampire EDL on Crushlocks
    2 in. extreme lift
    BRGR
    armor tech brush gaurd
    Hmf Performance exhaust
    Uni Air Filter
    Reverse Override
    Custom Snorkel
    2006 Honda Rancher 350
    Bone stock hunting bike
    Grizzly Man
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/23 21:19:28 (permalink)
    is ur choke ok. i had a couple people tell me something about the choke breaking and it floods the carb out.
    also. a boy come into the shop and told me the rancher 350 needle seat is made out of a very soft metel and if it gets trash in it that it will scratch it up. and the needle will not make a complete seal.
    and like said above cheack and make sure the float dont have a hole in it. because if it gets gas in it. it turns into a sink and is no longer a floAT
    IF YOU WONT STAND BEHIND OUR TROOPS FEEL FREE TO STAND IN FRONT
    1996 Yamaha Kodiak 400
    27" laws
    Jetted
    ITP Type 5's
    Cobra pipe
    2" lift
    350rancherboy
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/23 21:53:03 (permalink)
    some way or fashon your getting crud betweeen needle and seat, post a pic of needle valve. But clean gastank with lauqr thinner wash it REALLY good, clean petcock valve REALY good, put inline filter just in case (i did it helped) and clean carb REALLY good. I dont think the float setting is adj. so you cant have it off.
    good luck!
    1968 Chevy C-10 DD 355/3OTT
    kdmudfest
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/23 22:00:55 (permalink)
    put some sea foam in it,you can get it from any auto parts store.if there is a little trash in it it will hold the needle back and cause you to flood out bowl.if still a problem use a hammer on the bowl,and tap the bowleasy.hope you have some good luck with it
    Whitebandit
    Re:2002 honda 4x4 350 rancher carb problems 2010/03/24 22:28:51 (permalink)
    The floats good. I will try seafoam and reclean the carb. Maybe this will work/\.
      Team Carnage
    Whitebandit
    Re:2002 honda 4x4 350 rancher carb problems 2010/04/08 16:00:55 (permalink)
    Ok I bought a brand new carb. and its still poaring gas out the overflow tube. What now? Has anyone had this problem? Its even doing it when Its running. Help!!
      Team Carnage
    Whitebandit
    Re:2002 honda 4x4 350 rancher carb problems 2010/04/09 10:03:33 (permalink)
    I guess I just have a pos!!!!!!!!!!
      Team Carnage
    350rancherboy
    Re:2002 honda 4x4 350 rancher carb problems 2010/04/09 15:26:52 (permalink)
    chill out, if your just cleaning the carb. then your not doing anything! The nasty dirty gas from the tank is just going to come back thru into your carb.
    Flush tank with hose/pressurewasher/LAUQER THINNER
    clean carb. good with your way of cleaning (yamalube makes a carb cleaner its good but$).
    Be sure to take the fuel petcock off, and clean blow it out good too
    make your you dont forget anything
    and pm me if you have anohter ? because I dont get on here very often and wont realize you posted back. thanks good luck pal!
    str8ballen454
    Re:2002 honda 4x4 350 rancher carb problems 2010/06/01 16:09:30 (permalink)
    Whitebandit
    I was the kid that bock was talkin about and all it was the needle and seat were stuck wide open... the bike would still run but every time you would stop or just sit it would flow out like your talkin about..hope this helps
