Locked2001 Yamaha Kodiak 4x4
Mr.Bojanguls
2009/07/27 00:47:41 (permalink)
Ok guys heres the deal,
   Im mostly a honda guy foremans are my thing.. my gf loves to ride, she likes my foreman.. but she doesent like/know when to shift gears, she said she'd prefer and automatic. So after looking into them I DO NOT like honda's "hondamatic". so next in line was Yamaha. Im looking into the yamaha kodiak 400 4x4 2000'ish model. All she'd be riding in is trails... and lite mud. So what im asking.. is are the kodiak's pretty good all around machines, do they hold up well? What are yall's thoughts.
        ..Bojanguls
2013 Yamaha Rhino 700
> 26" Skinny/Wide Vampires
> In Dash Amp/Stereo Speakers
> 4000lb Viper winch
> Rear Diff Brace
> 1.75mm Sheave Shim
13 Replies Related Threads
    AlaskaGrizz
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 02:02:39 (permalink)
    I got a 2004 Kody 400 -bulletproof- rear drum brakes is the only thing I ever have to work on.
    09 Polar Bear HO 700
    modded out
    2005 660 Grizz
    HMF
    Dynojet
    Warn 2500
    Setxatv snorkles
    Steel skidplates and A-arms
    HL Super Duty Clutch kit
    HL Triple Flow Rad/ stock position
    Mr.Bojanguls
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 11:42:39 (permalink)
    Thanks, Any one else have some input?
    > 4000lb Viper winch
    > Rear Diff Brace
    > 1.75mm Sheave Shim
    Dezz
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 13:25:04 (permalink)
    Those Kodiaks are excellent atv's......my father in-law owns a 2001 model and I love it.
    They are also very reliable.
    I am not sure if its matter to you, but I prefer the earlier models of the 400cc Ultramatic....just because they had Low Range. You can use that machine for heavy work and towing if you ever needed it.
    After the 450 kodiak was released, Yamaha decided to remove the low range from the 400 model to increase sales of the similar designed, but more expensive (which means more profit) 450 model.
    If I was looking for a used 400ish model automatic atv, then the Kodiak is my first choice.
    Dezz
    2003 Yamaha Grizzly 660
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    - SOLD - But not Forgotten
    1998 Grizzly 600
    ITP Delta Black Chrome Rims
    4 - Kodiak 450 Clutch weights
    Uni Air Filter
    Warn A2000 Winch
    Oxlite CV joint protectors
    XLCat
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 14:21:55 (permalink)
    The Kodiak is tough as nails.  Tougher than the 400/450 foremans, and that's saying a lot.  The brakes are better, and there's no issues w the u-joint or left rear axle seal.  Plus they have more power.
    07 700 GRIZZLY---Outlaw MSTs: 28x9.5, 28x12; Warn 3000 w Amsteel, (4) CEC 1" spacers, UNI filter, 1.25" bar relocation, removed shifter lockout, exhaust tip, 9003 SilverStars
    01 Cherokee, Rusty's Long Arm setup, 4.5" coils, 3.5" leafs w 1.5" shackles, Rusty's HD trac bar and mount, Rusty's steering linkage and steering box brace, no sway bars, 8.8 rear w discs, HP Dana 30 front, 4.10s, hardcore front bumper---it'll flex just a tad!
    "Don't move, he'll do it!"
    gmcz71
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 15:07:34 (permalink)
    Id go for a 00-03 Kodi 400 SRA WITH the low.  I think in 03 or 04 the 450 came out and they stopped putting low gear on the 400.
    I want one of those kodi's in the future but it MUST have a low range.  my 05 Kodi 400 without low was pathetic in any mud or hill situation.
    justin99
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 17:42:06 (permalink)
    I have an 03 450 and love it. My wife rides it. Alot of power but not over powering.
    2010 Polaris Rzr 4 (Robby Gordon Edition)
    2005 Honda trx450r
    2008 Yamaha yfz450
    2009 Kawasaki kfx450r
    2005 Kawasaki Brute Force 750
    2008 Polaris Outlaw 50
    2005 Honda Rancher 350 ES
    chestnutglade
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 21:24:18 (permalink)
    I got a 2001 and 2002 kodiaks.They are easy to steer . Ride good.  Disk brakes are not that good.The pull rope starter get hot!!Enough power. The only bad thing there is no front def. lock.
    650 Brute force,28X12X12  MST's tires, spidermod Clutches , 2 inch HL lift kit,HL springs, custom 4 snorkels, moose module ,custom front and rear bumpers coated with rhino coating, custom skip plates , cycle country c v brush guards,4000lb  Viper MAX  WINCH Kit. 2nd bike (son's),2002 camo 400 kodiak ,4 - 660 rollers,orange secondary spring,2 inch lift kit,26-9-12 589 tires,3000lb viper max, 3 custom snorkels,Dynojet Kit
    Anne76
    Re:2001 Yamaha Kodiak 4x4 2009/07/27 23:10:23 (permalink)
    My first bike was a Kodiak 450. Its a great bike for a girl to start out on!
    yamaharider
    Re:2001 Yamaha Kodiak 4x4 2009/07/30 00:13:00 (permalink)
    i have the 06 kodiak irs and it is the best bike i have ever rode light and easy to handle the dif lock is a plus but ive never had to use it and i ride in some muddy places the best thing though is the high/low range that ultramatic holds up the best.
    1badgrizzly
    Re:2001 Yamaha Kodiak 4x4 2009/07/30 16:25:44 (permalink)
    Used to own a 01 kodiak 400.  Great bikes.  Those 400 yamaha engines will run forever if you keep them serviced.  GMCz71 made a good point about making sure if you buy a 400 that it has both high and low.  If you put 26 or 27 inch tires on them sometimes the 400 doesn't want to turn the tires good if your in thick mud.  Low range comes in handy.  However, the only downside is if your girl wants her bike snorkled.  Mine was a pain to snorkel.  At the time I couldn't find a kit that fit that bike so you'll have to make your own.
    08 Grizzly 700
    Black STIs
    29.5 Skinny/Wide Laws
    Super ATV Front Bumper
    2500# Warn
    450 Weights
    White EPI Clutch Spring
    Dawgriderdanny
    Re:2001 Yamaha Kodiak 4x4 2009/07/31 00:52:37 (permalink)
    what is the ultramatic, i found one thats in good cond for 1200,and i might buy it, SHould i?
    *Outty 800 Max ltd*
    *30" skinny silverbacks*
    *Wild Boar Rad relocated*
    *Sweet set of snorkels*
    *Full body skid plate*
    Dezz
    Re:2001 Yamaha Kodiak 4x4 2009/07/31 14:00:56 (permalink)
    Dawgriderdanny
    "Ultramatic" is just Yamaha's way of saying "Automatic".
    The Ultramatic Kodiaks are belt driven, just like every other automatic (except Honda) on the market. The differences come in the design. Yamaha has the best and most reliable belt drive setup right now. Even Suzuki and some Arctic Cats use almost the same design, with the same reliability of the Yamaha's.
    Dezz
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    1998 Grizzly 600
    Uni Air Filter
    Warn A2000 Winch
    ncmudman
    Re:2001 Yamaha Kodiak 4x4 2009/07/31 21:19:23 (permalink)
    Even thought I recently bought my Grizz 700, I still enjoy scootin around on the Kodiak every now and then! It just about will go anywhere any other ATV can go. The diff-lock really comes in handy!!
    MY VIDEOS
    09 Grizzly 700- MIDNIGHT MAGIC
     28" Radial Laws
    ITP SS108s
    HL Sealant
    1.5mm shim,
    EPI orange spring
    SuperATV Rhino Axles
    Barkers Dual Exhaust
    EHS Racing Intake, programmer
    Warn Front Bumper
    Moose HD rear bumper
    Fender Bars W/ pegs
    AP Skids
    Warn RT25
    Rock Sliderzz
    Tamarack Front Box
    Rotopax 4gal gas pack
    Moose Handguards
    Rigid Industries D2 LED Lights
