Locked2001 Big Bear hard shifting
muck chucker
Dirt Monster
2011/05/09 15:52:16 (permalink)
My Brother just bought a 2001 big bear 400 and it is quite hard to shift from rev to nuetral or forward.  Just wanted to hear from you guys if this is a common problem or if there is linkage that needs to be adjusted, lubed, or if were just doing somthing wrong.  Some times u can move the lever out of reverse but it stays in gear.  This is the hand shifter not the foot.  Its also called a profesional series does anyone know what that means?  Any help would be awsome.
6 Replies Related Threads
    goatroper420
    Re:2001 Big Bear hard shifting 2011/05/09 16:06:02 (permalink)
    try adusting the clutch on the side of the case
    1997 Honda 300
    new plastics, fuel tank,
    rear brake delete
    15% gear reduction
    snorkeled
    warn 2500 mt winch
    warn 2-4-2 select
    28 outlaws
    sodona wheels
    2inch lift
      Team Outlaw Motorsports
    billyj7175
    Re:2001 Big Bear hard shifting 2011/05/09 16:21:30 (permalink)
    I don't have the same year/setup as the bike you're talking about, but mine goes into reverse just fine, but is picky about shifting 'out' of reverse.  It goes in easily, but it seems as if you have to have slack in the drivetrain in order for it to shift.  What I mean is, you sort of have to back up in a straight line, let off the gas and shift it right as it comes to a stop.
    07 Big Bear 400/SS212/28 X 9.5 MST's/HMF Penland Pro/UNI Filter ---SOLD---
    You'll have to excuse my manners...my inner voice has Tourette's...
    BodySnatcher
    Re:2001 Big Bear hard shifting 2011/05/09 20:58:00 (permalink)
    Is it idling high?
    crewsro
    Re:2001 Big Bear hard shifting 2011/05/12 00:06:04 (permalink)
    I have the same problem with my 2010 BB400, I have to sometimes either rock the 4wheeler with body weight while shifting out or I have to reverse just a little bit more while trying to shift out.  Also, I've noticed with mine that sometimes when I shift out of reverse, it shifts to neutral and sometimes it shifts straight to first, even if I always go from neutral to reverse.
    BridelessRacing
    Re:2001 Big Bear hard shifting 2011/05/12 08:18:30 (permalink)
    run your iddle as low as possible. and add 5 oz of jb engine tuneup to the oil.
    Don Oglesby on facebook
    usefull
    420 gr
    monsterbear1
    Re:2001 Big Bear hard shifting 2011/05/14 12:16:58 (permalink)
    your bike is simply idled up to high more than likely turn bike off and try shifting if it works fine then there is just idle problem
    2004 big bear 400
    32in silverbacks
    14inss112 rims
    hmf penland
    aftermarket valves and springs
    bored.40 over
    web cams
    jet kit
    hl lift kit
    snorkled
    2007 polaris ranger 700
    2in lift
    27 mudlights
    212 black chrome rims
    all speakers you could need
    2000 honda 300
    4in lift
    4in stretch
    modified motor
    combra exhaust
     sponsered by 2 D CYCLE PARTS
    all your used parts for great deals
    662 528 4381 or 662 746 9948
    yazoo city, ms
    http://www.2dcycleparts.net/
