Hot!2000 sportsman 500 charging question
Countyrboy_2
2018/10/21 11:25:41 (permalink)
My sportsman will charge then it stops then starts again ect. When it stops charging 20 amp breaker clicks and regulator is overcharging. My question is Is my regulator bad or stator. Thanks
5 Replies Related Threads
    Re: 2000 sportsman 500 charging question 2018/10/21 14:52:00 (permalink)
    Your gonna have to check your stator to know for sure. Here's a link to help troubleshoot the issue.
    https://www.google.com/ur...mp;cshid=1540151272971
    Countyrboy_2
    Re: 2000 sportsman 500 charging question 2018/10/21 16:57:51 (permalink)
    Thanks. Will try that first chance I get
    Countyrboy_2
    Re: 2000 sportsman 500 charging question 2018/10/23 18:53:16 (permalink)
    Ok I couldn't get to the web site you posted but I ohmed my yellow and yellow/ red and only have from .7 to .0 ohms and checked both LEDs to ground and they both have like 4. something so I'm guessing it's my stator concedering there should be none to ground from what I have read
    Re: 2000 sportsman 500 charging question 2018/10/23 19:44:48 (permalink)
    Yes if your stator is not giving you hardly any resistance it's probably shot and might have hurt your votage regulator as well. So if I was you I'd change both.
    Countyrboy_2
    Re: 2000 sportsman 500 charging question 2018/10/23 19:46:47 (permalink)
    Thanks. That's what I thought.
