Hot!2000 ranch treefiddy
alexg89
2018/12/03 11:08:01 (permalink)
So i picked this thing up for 500 bucks.. Had to redo the whole frame because it was all rotted
Stuck some 28x12s OG outlaws all the way around and well shes a pig.. i keep seeing all the GR threads and once i get money ill go that route
What i cant seem to find is an alternative to make this thing selectable 4x4 and i cant find a good carb to stick on it that doesn't have the darn vacuum crap all over it
I bought an after market carb and put it on .. hooked up the fuel heater and well it shorted and my thumb throttle got about 150 degrees lmfao so pretty sure the carb is hurt and thats why its loading up and runs like shissss
Thanks for any help guys
post edited by alexg89 - 2018/12/03 11:14:51
46 Replies Related Threads
    Re: 2000 ranch treefiddy 2018/12/03 15:06:50 (permalink)
    I did the 400at diff swap on my 350 rancher and it works super good!!! I used the 400 front diff, drive shaft and the 2wd/4wd switch from the 400, I changed the top cap in order to get rid of the auto/ESP switch. This is a direct fit, the only mod that has to be done a small V needs to be cut out of the 350 frame in order for the bigger diff to fit (you will see when you set the diff in place) the 400 has this cut out from the factory so it will not weaken anything! everything bolts right up no trouble at all! The wiring is just as easy also, you will only need two wires on the front diff. the orange and the white that switches it on and off, it will be the only two wire plug on the diff, cut the 2 three wire plugs off and toss them, there is only two wires on the diff now, orange is + white is - hook the white wire to ground and the orange wire to either wire to the 2wd/4wd switch then hook 12v from the key switch to the 2nd wire on the 2wd/4wd switch. that's it you are done. REMEMBER TO ONLY SWITCH 2WD/4WD WHEN YOU ARE AT A COMPLEAT STOP!!! works 100%!!! God bless.
    Hope this helps.
    alexg89
    Re: 2000 ranch treefiddy 2018/12/03 15:28:59 (permalink)
     400 front diff, drive shaft and the 2wd/4wd switch from the 400, I changed the top cap in order to get rid of the auto/ESP switch.The wiring is just as easy also, you will only need two wires on the front diff. the orange and the white that switches it on and off, it will be the only two wire plug on the diff, cut the 2 three wire plugs off and toss them, there is only two wires on the diff now, orange is + white is - hook the white wire to ground and the orange wire to either wire to the 2wd/4wd switch then hook 12v from the key switch to the 2nd wire on the 2wd/4wd switch. that's it you are done.
    Hope this helps.
    Sweet deal.. I found a front diff.. do i just need the prop shaft to go with it ??
    if so ill buy it now.. Also i could just run power to a push button switch correct? mount one on the fender and call it a day?
    Re: 2000 ranch treefiddy 2018/12/03 16:57:50 (permalink)
    Exactly!!
    alexg89
    Re: 2000 ranch treefiddy 2018/12/03 17:06:26 (permalink)
    awesome ... last tning.. stock  cvs fit just fine corect?
    Re: 2000 ranch treefiddy 2018/12/03 17:18:37 (permalink)
    Yep
    BUSHHOG
    Employee
    Re: 2000 ranch treefiddy 2018/12/04 08:25:28 (permalink)
    Outstanding help 00_NUTT...............thank you. We made a good decision to make you a mod !!! Keep up the great work.
    Dan Doughty
    Re: 2000 ranch treefiddy 2018/12/04 08:36:07 (permalink)
    I'm trying Sir!!!
    alexg89
    Re: 2000 ranch treefiddy 2018/12/04 08:46:57 (permalink)
    I will say im glad theres people that know these things inside and out.. My knowledge lies among Nissan stuff lmao and i work for a classic car restoration company.. tell me how that works.. Ive had a few hondas in my day but this is my first rancher.. ill be ordering up the front diff and prop shaft this friday and hopefully get this pig going
    Thanks again guys i do appreciate it
    And heres a picture of the old girl
    Re: 2000 ranch treefiddy 2018/12/04 09:43:26 (permalink)
    Alexg where you located if I may ask? Also your pic didn't load. So big question. What pimp car do you roll?
    alexg89
    Re: 2000 ranch treefiddy 2018/12/04 10:07:48 (permalink)
    Im in good ol Cocoa Fl .. beach side .. and ive tried posting a few links for pictures since i cant seem to figure out how to post acutal pictures lol neither of them work
    And ive got a 95 nissan harbody ive had for 14yrs (since i was 15) and its slammed .. Done a 5 lug conversion on it, mini notch, 17s, pathfinder fenders and seats.. bunch of little stuff.. trying to get all the body work done and readdy for paint
    post edited by alexg89 - 2018/12/04 10:17:39
    Re: 2000 ranch treefiddy 2018/12/04 10:29:36 (permalink)
    Sweet. I always loved the mini truck scene. I had a 99 Chevy 1500 bagged and body dropped on 22's. Had everything shaved with the wall cut out on it. Then I had kids hahahaha. So now it's all travel ball and highlight films for colleges!!!
    alexg89
    Re: 2000 ranch treefiddy 2018/12/04 14:57:23 (permalink)
    Right on man sounds legit.. No kids for me yet, golf cart, gopeds, 1/10scale rc crawlers, and my mini lol oh and i have a scooter cooler.. all about the toys right now hahah almost 30 so i should probably get into the family thing hahah
    Re: 2000 ranch treefiddy 2018/12/04 21:22:32 (permalink)
    I have 5 Honda 300's, 2 Honda 100R dirt bikes with big bore kits, home built bad A drift trike and my crew cab GMC sitting on 22's with a 4 6 drop. So at 40 I still have some fun hahahahaha
    alexg89
    Re: 2000 ranch treefiddy 2018/12/05 07:53:02 (permalink)
    So i was gonna buy the little 2inch lift they have for the ranchers.. does it really put that much more wear and tear on the cvs and rear ujoint? i had a recon back in the day and i had a lift on it and i dont remember any such issues
    Any insight on this?
    alexg89
    Re: 2000 ranch treefiddy 2018/12/05 07:55:05 (permalink)
    and talk to me about this 317 Kit and Big Red Cam.. you seem to know your way around these pretty good
    My buddy just scored a 300 fourtrax and its mintyyy
    post edited by alexg89 - 2018/12/05 07:57:34
    Re: 2000 ranch treefiddy 2018/12/05 09:03:21 (permalink)
    Man I ran those two inch lifts from the early days and never had an issue. The 317 kit is this. A rancher 350 sleeve in a 300 jug. So the jug has to be bored to receive the 350 sleeve. Use rancher 350 piston and have to either get a special gasket from cometic gaskets or double or triple gasket up. Just call cometic and tell them and they know. The reason is the piston comes up a hair higher and will smack the valves without it. And the cam is just a little hotter. It's a really reliable setup since it's all factory Honda parts. Throw a 54% gr and you will have a beast. Also tell him to find a 350D rear axle and put it on his 300. It's a fully sleeved axle and is basically bullet proof.
    alexg89
    Re: 2000 ranch treefiddy 2018/12/06 07:30:39 (permalink)
    Roger that sounds good... Now as for my 350, is there an alternate carb that dosnt have all the vacuum crap on it? could i use like a mikuni 32 or one similar off another honda?
    Re: 2000 ranch treefiddy 2018/12/06 07:40:17 (permalink)
    Man you can run a 300ex carb but will have to play with the jetting on it. Will also have to run a k&n filter and exhaust since the carb will flow more fuel.
    #19
    alexg89
    Re: 2000 ranch treefiddy 2018/12/06 08:11:19 (permalink)
    you think it would flow more for less cc? i can lean it out that wont be a problem lol just wasnt sure if there was a good one to pop on and ride.. this vacuum crap sucks
    #20
    Re: 2000 ranch treefiddy 2018/12/06 08:40:16 (permalink)
    I think the main thing is the pilot jet. Needs to be like a 45-48. Besides that the main should be fine with a couple of needle adjustments. Yes vacuum carbs suck!!!!
    #21
    alexg89
    Re: 2000 ranch treefiddy 2018/12/11 16:20:52 (permalink)
    00_NUTT  if you will please, email me
    I want to send you a picture to confirm something for me
    Thank you sir !
    #22
    Jeepwm69
    Re: 2000 ranch treefiddy 2018/12/13 10:23:51 (permalink)
    alexg89
    Get some 07-13 420 knuckles, hub/rotors, and calipers to go on the front too.   Bolts right on at the ball joints and uses all factory parts.
    #23
    alexg89
    Re: 2000 ranch treefiddy 2018/12/13 10:26:40 (permalink)
    Jeepwm69
    alexg89
    Whats the benefit from this if i may ask other then brakes?
    #24
    Re: 2000 ranch treefiddy 2018/12/13 11:51:18 (permalink)
    Disk brakes!!!! Cause drum brakes suck!!! A lot cheaper than buying the conversion kit. I scored all my 420 parts for like $75.
    #25
    Jeepwm69
    Re: 2000 ranch treefiddy 2018/12/19 14:06:42 (permalink)
    What Nutt said, disc brakes.
    Drums suck and to redo drums you'll spend more than discs will cost, and the drum brakes won't last.
    #26
    alexg89
    Re: 2000 ranch treefiddy 2018/12/20 12:05:09 (permalink)
    So i got all the differential stuff in . waiting on the speed sensors since i got shorted those ..
    I can tell you im ready for some 2wd **** cause this thing is a pig in 4wd lol
    Next thing, i really dont want a loud exhaust but whats the next step for a little more kick
    Budget doesnt really work for a GR, do the CDI boxes help at all?
    #27
    Re: 2000 ranch treefiddy 2018/12/20 12:29:34 (permalink)
    Cdi helps a little but nothing great. You could get you a slip on exhaust and jet the carb and a k&n filter. GR is the best bang for the buck hands down. The other options will give you a little but depending what you spin determines if it was worth it or not.
    #28
    alexg89
    Re: 2000 ranch treefiddy 2018/12/20 12:32:42 (permalink)
    any particular Cdi to look for .. brand wise that is
    #29
    Jeepwm69
    Re: 2000 ranch treefiddy 2018/12/20 14:02:19 (permalink)
    alexg89
    You don't need functional speed sensors.  I snipped the wires off of mine.  The 350 Rancher speed sensor is on the back of the motor above the rear output.  You do need speed sensors on that diff to fill the holes though.  Get the cheapest ones you can find on ebay from an 02-04 450, Rincon, 05-14 Rubicon, 05-11 Foreman, or 400AT.  Speed sensors for all of those are the same size.  Bolt them on, snip off the wires.
    #30
