Hot!2000 big bear 400 no spark
DB32
2017/04/03 17:57:43 (permalink)
Alright guys. I am stumped on this thing. When I turn key on it has no neutral light or oil light. I have power to headlights when the key is on and no headlights when the key is off. When I turn key on it does nothing. No relays click or anything and No spark when I jump starter solenoid. Starter solenoid is brand new. Any help is appreciated. Need to get this bike running ASAP
2000 Big bear 400
29.5's
Oil cooler/fan relocate
Fan on switch
Lil work In the top end
LEDs everywhere
6' tribal whip (red)
BROOKHAVEN BOYZ
11 Replies Related Threads
    doveman1
    Re: 2000 big bear 400 no spark 2017/04/03 19:17:25 (permalink)
    Check all your fuses?
    Green 2015 Grizzly 700
    DB32
    Re: 2000 big bear 400 no spark 2017/04/03 23:26:04 (permalink)
    Yes they are all good. I checked the starter and kill switches too and theyre good.
    2000 Big bear 400
    29.5's
    Fan on switch
    LEDs everywhere
    BROOKHAVEN BOYZ
    • Status: online
    Re: 2000 big bear 400 no spark 2017/04/04 06:39:04 (permalink)
    Probably a bad coil or CDI box.
    DB32
    Re: 2000 big bear 400 no spark 2017/04/04 08:39:40 (permalink)
    Is there a way to check the CDI or the primary coil?  Would the primary coil being bad keep the neutral and oil lights from coming on? How do i check the neutral switch?
    2000 Big bear 400
    29.5's
    Fan on switch
    LEDs everywhere
    BROOKHAVEN BOYZ
    • Status: online
    Re: 2000 big bear 400 no spark 2017/04/04 09:38:34 (permalink)
    Get you a service manual. You can check a coil but I think that is not your problem since you say your lights are not coming on. To check neutral switch you need a volt meter and set to ohms. Get across the two electrical pins for it and actuate the switch. The meter should go from OL to some ohm reading.
    DB32
    Re: 2000 big bear 400 no spark 2017/04/05 17:40:07 (permalink)
    I found a schematic and tested all the sensors and such and had no luck. I also found a melted ground wire in the harness. It's melted from the ignition coil to the last spot where they join more wires in and go to frame ground then the cdi. Would this cause it to keep burning up cdi's? This will be the second one I've had to put in it for the exact same reason and they aren't too cheap.
    2000 Big bear 400
    29.5's
    Fan on switch
    LEDs everywhere
    BROOKHAVEN BOYZ
    • Status: online
    Re: 2000 big bear 400 no spark 2017/04/05 18:58:43 (permalink)
    Very good possibility.
    Dezz
    Re: 2000 big bear 400 no spark 2017/04/07 18:29:13 (permalink)
    DB32
    Yes this is why your CDI failed.
    2003 Yamaha Grizzly 660
    Dalton Clutch Kit
    2500 lbs. WARN
    High Strength Axles
    - SOLD - But not Forgotten
    1998 Grizzly 600
    ITP Delta Black Chrome Rims
    4 - Kodiak 450 Clutch weights
    Uni Air Filter
    Warn A2000 Winch
    Oxlite CV joint protectors
    DB32
    Re: 2000 big bear 400 no spark 2017/04/10 16:38:38 (permalink)
    Alright yall I changed the cdi and it still does nothing. No relays click or anything. And no lights come on. I cleaned all the connectors and put di-electric grease in them. What do the 2 relay looking things do and also the small black block (not voltage regulator)
    2000 Big bear 400
    29.5's
    Fan on switch
    LEDs everywhere
    BROOKHAVEN BOYZ
    DB32
    Re: 2000 big bear 400 no spark 2017/05/09 18:27:29 (permalink)
    Replaced black block and it ran fine it just died while I was riding and the oil light doesn't come on when I hit start button anymore. What could be my problem???
    2000 Big bear 400
    29.5's
    Fan on switch
    LEDs everywhere
    BROOKHAVEN BOYZ
    Swamp_nut
    Re: 2000 big bear 400 no spark 2017/05/24 10:21:49 (permalink)
    Does it turn over?
    '03 Yamaha Big Bear- Smokey
    2" lift
    coming soon:
    snorkel
    tires
    pipe
    clutch
    jet kit
