Hot!2000 Polaris sportsman 500 want start after been ran and charging question
Countyrboy_2
2019/02/16 22:33:31 (permalink)
Replace stator today and reset valves. Reason for replacing stator was that it was charging but would stop charging and start again but got to where it was not charging more than it was charging and new stator and regulator is doing same thing . And after it has ran for a while and you kill it, it will not start till it cools completely off. Any ideals ??????
4 Replies Related Threads
    Re: 2000 Polaris sportsman 500 want start after been ran and charging question 2019/02/17 13:41:10 (permalink)
    Sounds like you have a voltage regulator going out.
    Countyrboy_2
    Re: 2000 Polaris sportsman 500 want start after been ran and charging question 2019/02/17 15:59:20 (permalink)
    Just put it on there when I did stator and found my cam worn on running and starting part
    Re: 2000 Polaris sportsman 500 want start after been ran and charging question 2019/02/17 16:09:38 (permalink)
    My bad I read to fast. So a new stator and regular. Now your cam is worn on running and starting part? I'm a little confused with that part.
    Countyrboy_2
    Re: 2000 Polaris sportsman 500 want start after been ran and charging question 2019/02/17 20:52:15 (permalink)
    Yes I replaced the regulator and stator yesterday and reset valves. Cranked it up and it was running ok at idle so I let it get warmed up good took it for a ride was running bad so got it home and checked voltage and it was charging and then it would stop and then start again and so on. Same way other stator and regulator we're doing .. The charging issue is all I am worried about now. Thanks
