Locked2000 Big Bear 400 4X4, drive shaft and u-joint help
bowanna03
2012/02/17 14:35:53 (permalink)
I have a 2000 big bear 400 4X4 and the shaft to make it four wheel drive is gone.  I purchased one cheap with all the u-joint and yokes attached.  Can anyone help me with how to remove the old yokes and u-joints.  They are still attacehd to the from diff and the bottom of the motor.  I will attach some pictures also
Attached Image(s)
8 Replies Related Threads
    bowanna03
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/17 14:37:13 (permalink)
    Rear pic
    Attached Image(s)
    bowanna03
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/17 14:41:57 (permalink)
    New/used parts that have to be installed
    Attached Image(s)
    yamaha guy
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/17 15:52:18 (permalink)
    there are C-clips that hold the universal joints in there, gonna have to nock some of that crud off to be able to see them. once you get the C-clips out its just a matter of hitting the cups until you drive out the opposing cup then rotate the yoke so you can nock out the other side. I marked them in a picture but I am unsure of how to post pics here.
    bowanna03
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/17 18:41:14 (permalink)
    Thanks for the info.  Tomorrows project.  If you have pics can you send them to my email it is jtggw@yahoo.com
    nastybear03
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/17 22:16:45 (permalink)
    Then they have a huge bolt nd that's it
    2003 Honda 450 es stock
    Under construction right now for
    ---extremerancher IRS conversion
    --- 35%gr
    --- 3" body lift
    For sale- 08 big bear body lifted frame
    08 grizzly 700 diff
    2000 450es front diff and rear diff from swingarm back off a bike with 200 miles
    yamaha guy
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/19 07:49:22 (permalink)
    IF you look at the new set up you have that should help you out alot as to where the C-clips are.
    BridelessRacing
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/19 09:22:16 (permalink)
    Set bike on blocks or hang from hoist so you can roll driveline while assembling u joints in the bike
    This job is a pain
    Don Oglesby on facebook
    usefull
    420 gr
    bowanna03
    Re:2000 Big Bear 400 4X4, drive shaft and u-joint help 2012/02/20 17:06:49 (permalink)
    Thanks guys
