Locked1998 Arctic Cat 300 4x4
Rdh605
2008/12/15 10:25:08 (permalink)
My dad just bought a used Cat for $500 that needs the carb cleaned, tires and brakes.  Easy enough to fix.  Here is the question, I have NEVER messed with AC bikes.  Are these tough bikes?  Any known issues?  Thanks guys!
Rdh605
2004 Honda Rubicon
26" MudLite XL's/Warn 424/Viper Max 3000lb winch
2004 Suzuki Eiger Auto
02 Kawasaki Bayou
     Mudlights
04 Honda Rancher 2wd
     27" Gators
92 Arctic Cat 300 4x4
     Mudlight AT's
98 350 Big Bear 4x4
     Mudlight XL's
82 Honda ATC 200m
Pics and Vids
www.youtube.com/RDH605
http://www.myspace.com/tnmudslinger
21 Replies Related Threads
    8upwithmud
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 11:11:26 (permalink)
    easiest in the world to work on.  Issues?  The carb on a 300.  Seems like you are always cleaning them out.  Tough bike though.  I'm putting a starter clutch in one right now.
    05 650 V2
    B&J lift, Gorrila's, 4.0's, snorkels, Hmf Penland, Dynojet, Epi clutch, Dynatek, 29.5x12x12 Laws.
    Used to be a 730cc with Wiseco's and mudbusters.
    Workin on a 750 Brute EFI motor swap with Wiseco's,   PC3, and Webcam 150i's
    04 500 manual
    Custom aluminum airbox, 28 Laws.
    05 400 Auto
    27 Mudlites
    06 Night Rod
    D&D Slip-ons, Vance & Hines FuelPak,
    200 Metzler rear tire.
    She'll go...
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 11:54:08 (permalink)
    ORIGINAL: 8upwithmud
    The carb is the problem on this one.  I will be picking it up tonight to see what all I have to do to get it back in top shape.  [;)]
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    TCAT
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 13:10:04 (permalink)
    They're like little tanks!  Very tough i've never had any major trouble with mine!
    GO GATORS!
    '08 THUNDERCAT
    '99 AC 300 4X4
    '98 AC 400 4X4
    '01 SCRAMBLER 90
    TEAM BONEHEAD RACING #13
    POWERED BY:
    Blue Pond ATV Park
    leed1315
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 14:25:57 (permalink)
    If I'm not mistaken these have the same motors as the 300 Suzuki king quads and are very similar bikes. Do these bikes also have the differential lock and super low?
    Bikes
    07 400 Big Bear
    08 650 Prowler
    09 Polaris Sportsman 90
     I part bikes out on the side and have between 40-50 bikes on average. Feel free to ask me about parts if you need something.
    Venbone
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 14:53:36 (permalink)
    2014 Wildcat Trail
    Past Bikes:
    2007 400m
    1999 300
    2007 400m with 2007 581m engine
    2009 Thunder Cat H2
    2008 650H1
    2005 300
    2009 700 H1 Max4 Camo
    Ranger 500 LE
    TCAT
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 15:15:41 (permalink)
    THEY LOOK PRETTY GOOD FIXED UP TOO!!![:D]
    GO GATORS!
    '08 THUNDERCAT
    '99 AC 300 4X4
    '98 AC 400 4X4
    '01 SCRAMBLER 90
    POWERED BY:
    Blue Pond ATV Park
    Venbone
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 15:42:36 (permalink)
    TCAT where did you get the black plastics?
    post edited by Venbone - 2008/12/15 20:36:57
    2014 Wildcat Trail
    Past Bikes:
    2007 400m
    1999 300
    2009 Thunder Cat H2
    2008 650H1
    2005 300
    Ranger 500 LE
    TCAT
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 15:50:43 (permalink)
    CLEAN THE STOCK PLASTICS WITH A SCOTCH BRITE PAD AND KRYLON FUSION PAINT!
    GO GATORS!
    '08 THUNDERCAT
    '99 AC 300 4X4
    '98 AC 400 4X4
    '01 SCRAMBLER 90
    POWERED BY:
    Blue Pond ATV Park
    walkingcrow
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 17:06:14 (permalink)
    There is an easy free mod to make the front diff lock on the older 300's. Do a search on here.
    WC
    AC 05/500 extra lighting front and back, modded muffler, 2" snorkel, purple epi clutch springs, carb slide mod, k&N, heated grips, gun racks, racks and bumper line-xed, WYO shock bushings, temp gauge, 27" Outlaws on T7's
    rad soon to be re located.
    There is no reason a 600lb machine shouldn't catwalk and drive through 6 feet of water.
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/15 20:18:34 (permalink)
    OK his looks no where near that good lol.  But I ain't started yet either[;)].  OK a few more questions...where can I get parts like a seat and the mug guards? I have not called my local stealership yet, but I wonder about aftermarket. I have found a few places with engine and mechanical parts..but I need some plastic...the small mudflap on the back to be exact, and his seat is pretty rough.[:-]
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/22 13:56:35 (permalink)
    Cleaned out the carb (man it was BAD) and it fired right up.  Running great, just need to adjust the idle a little. Also the brakes were none existent, found a caliper leaking fluid.  Removed it and the brakes were gone and the piston in the caliper is what was rubbing the rotor!  The piston had came out past the rubber O ring and was leaking.  Took it off and cleaned it out, put in new brakes and it's working fine.  So the only thing left it cosmetics.  Someone hit something with it and has done some damage to the front grill, I found the whole front end NEW for $89.  Can't wait to get it done for him.[:D]
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    04 400 4x4i
    RE: 1998 Arctic Cat 300 4x4 2008/12/22 18:04:52 (permalink)
    some pics of the work in progress would be awesome. and the krylon fusion is an option but I have come to find etching primer and good quality spray paint to be better. just my opinion. But keep us posted and good luck. Sounds like you have had some of that already.
    2004 ARCTIC CAT 400 4x4i
    Snorkeled, Clutched and Clocked, Exhausted
    27" Swamp Lites
    14" ITP 312s
    northern quad
    RE: 1998 Arctic Cat 300 4x4 2008/12/22 18:28:17 (permalink)
    Can't wait to see some pics those bikes were mini tanks just like the zuki 300's and with that super low gearing were darn tough to stop in almost any hole.  Keep us posted sounds like it is coming along good.
    2007 Suzuki KingQuad 450
    Two upseat installed
    2500# warn winch
    Flare quick release windshield by kimpex
    Heated handle bar warmers and muffs added
    Swamp Lites on stock rims 26x10x12-front and 26x12x12-rear
    Father's bike
    2007 Polaris 500 H.O EFI X2
    Stock tires
    New Truck:
    2010 Chevy Silverado LS
    Crew Cab
    4wd
    Granite Blue Metallic
    Tonneau cover installed.
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/23 06:21:59 (permalink)
    I will get some pics of it tomorrow.  It's rough on cosmetics but runs like a sewing machine! Dad wants to ride it a while to make sure it is going to hold up before he drops any money on the body[&o]  With the engine setting so far back is this thing light on the front end climbing hills?  I have only had it around the house so far.
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    8upwithmud
    RE: 1998 Arctic Cat 300 4x4 2008/12/23 08:29:17 (permalink)
    You will be surprised how well it climbs.  It's very predictable.  I wish they still made those.
    05 650 V2
    04 500 manual
    05 400 Auto
    27 Mudlites
    06 Night Rod
    She'll go...
    bpLAcat250
    RE: 1998 Arctic Cat 300 4x4 2008/12/24 08:05:12 (permalink)
    any pix?
    06 Arctic cat 250
    spark arrestor removed
    1500lb warn winch coming soon
    GOD BLESS the USA
    If you ai'nt ridin' a cat and you ride with me you are gonna get stuck!
    Who said CATS didn't like water?
    racing Honduhhs is like the special olympics,
    because if you win you're still retarted
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/25 19:54:18 (permalink)
    Here is some pics of the cat he got.  This is after I straightened the front end.
    Attached Image(s)
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/25 19:57:54 (permalink)
    another
    Attached Image(s)
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    #19
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/25 19:59:26 (permalink)
    last one
    Attached Image(s)
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    #20
    Rdh605
    RE: 1998 Arctic Cat 300 4x4 2008/12/28 21:02:25 (permalink)
    Cleaned carb/rebuilt brake caliper/fixed front end/new brakes/adjusted the foot brake and cleaned the rear brakes/drained fuel tank and put in new fuel/....it run's PERFECT!  I can't believe how well it is running and it rides great. My dad is tickeled with it.  Only thing is getting used to the heel/toe shifter!
    Rdh605
    2004 Honda Rubicon
    02 Kawasaki Bayou
         Mudlights
         27" Gators
         Mudlight AT's
    98 350 Big Bear 4x4
         Mudlight XL's
    82 Honda ATC 200m
    Pics and Vids
    #21
    kidsoncoffee
    RE: 1998 Arctic Cat 300 4x4 2008/12/28 21:07:27 (permalink)
    My old 300 2x4 would run with most 4x4s.  It was LIGHT.  Having that weight on the rear of the bike definately helped with traction.  And the integrated IRS was a wierd touch on the bikes.
    2008 Big Bear 400 4x4
    X.P.  2" Lift
    Custom 2" Snorkel
    27" MudZillas
    3 Gorillas and one clicker...
    DynoJet Jet Kit
    UNI Filter
    55W Halogen on the Back
    More to come......
    #22
