Hot!1991 300 fourtrax 2wd
Hcoboyzzzz18
2019/04/09 10:32:18 (permalink)
Looking for some axle paddle ideas. Which rear end do I need to get? And what’s the best way to get a lot of lift? And is there a way to keep the 300 rear end and install paddles on it?
1 Reply Related Threads
    Re: 1991 300 fourtrax 2wd 2019/04/10 13:14:36 (permalink)
    Best rear axle assm to use is the 350D. The 350D has a bigger diff. You section out the center housing to gain access to axle. Find a pipe that is roughly the same diameter. Split it and we'll your paddle to it and make it to where it can be bolted back together so it clamps to the axle. Only true way for a lot of lift is a customer lift or do a body lift to the frame.
