1986 trx350 gear reduction
HurtinAlbertan
2018/01/15 22:28:50 (permalink)
hey guys, I'm sure this pops up on here all the time but I'm just starting to think about putting a gear reduction in my old 1986 trx350 4x4. This past summer i made a 2" lift for it and jumped up to 26" zilla's. It was a massive improvement and is great on the trails but gets bogged down in the skeg and thick mud. I haven't really researched it too much yet but I'm just looking for some knowledge if anyone has any :P I'm not even sure what all I'd need as far as clutch kits, clutch baskets, which gears to hunt down (probably looking for somewhere between a %15-%35 reduction) and whatever else I would need. I figured there's probably some guys on here that have done this before and could shed some light on what parts I should be trying to hunt down. Any info would be greatly appreciated, Thanks!
7 Replies Related Threads
    Re: 1986 trx350 gear reduction 2018/01/15 22:38:26 (permalink)
    Here check this link. Probably cheaper and easier than having to hunt everything down and machine it all to fit.
    https://m.ebay.com/itm/Ho...eduction-/112572998734
    post edited by 00_NUTT - 2018/01/15 22:39:54
    HurtinAlbertan
    Re: 1986 trx350 gear reduction 2018/01/15 22:48:01 (permalink)
    Thanks, that was pretty much exactly what I was looking for. It says that that's a %14.5 primary drive reduction, in simple terms cause I'm a dummy what does that mean exactly, is it only a reduction on my first gear or does it give me lower gearing thoughout all my gears?
    Re: 1986 trx350 gear reduction 2018/01/15 22:52:05 (permalink)
    It's going to gear every gear down 14.5%
    Re: 1986 trx350 gear reduction 2018/01/15 22:53:17 (permalink)
    It should do you fine
    post edited by 00_NUTT - 2018/01/15 22:54:29
    HurtinAlbertan
    Re: 1986 trx350 gear reduction 2018/01/15 22:57:06 (permalink)
    Beauty, that's kinda what I thought but I wasn't sure. Thanks for the info, I'll look into getting that kit!
    HurtinAlbertan
    Re: 1986 trx350 gear reduction 2018/01/15 22:59:12 (permalink)
    I also read that you could run 28-29" tires with that kit. My little 26's should throw mud pretty **** good after this lol
    Re: 1986 trx350 gear reduction 2018/01/16 07:35:25 (permalink)
    Yea you should be good between the GR and the power of that old school 350. That's a good motor!!!
