Hot!08 grizzly 450 no spark
grizzagator450
2019/10/07 17:09:48 (permalink)
I was jump starting a dead battery and when it started the positive cable shorted to the frame. I didn't notice this till I noticed smoke coming from under the counsel and the engine died. Now it has no spark. I checked all fuses and verified there is voltage at the fuse. Where should I go next? Could it have smoked the stator or ignition coil?
Thanks
08 Grizzly 488
Running e85
Ported
Jeted
Cluched
Lifted
Scuba gear
30"
1 Reply Related Threads
    Re: 08 grizzly 450 no spark 2019/10/08 10:24:18 (permalink)
    Very good possibility. I'd start with the ignition coil. If your battery is hot it should have spark regardless of the stator.
