Locked08 Raptor 250 JB weld Stator cover and metal shavings question
JOE G
Dirt Monster
2016/11/17 16:11:05 (permalink)
So I took the cover off for the gear that engages with the starter gear and the case inside was scuffed/gouged up and there was some metal shavings it appears that they never put the dowel/spacer rod back in so the gear was rocking which probably is why the starter is hanging up.
The cover was also cracked ( Hair line Been having a oil leak issue ) where that gear rides right below the started nose. I cleaned everything up and scuffed up the cover inside and out where the crack is and JB Welded it. I am now waiting for dowels, gaskets and some other odds and ends and I will put it all back together.
I am a bit nervous about having JB weld inside the case even though I just put a thin layer to kinda just stop the leak and put in on much thicker on the outside.
I also hope not to much metal is inside the engine.
Do you guys think JB weld will be ok in this situation? I am guessing when the starter is engaged there maybe be some pressure on the case.
2006 ARCTIC CAT 650 H1 LE.
2002 GSX-R 750.
2002 HONDA ACCORD.
1986 Z28 COMPLETE REBUILD GROUND UP ROAD RACER.
10 Replies Related Threads
    bcom
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/17 18:55:42 (permalink)
    Ive seen guys use jb weld to fix oil pans and engine blocks. Im willing to bet youll have good luck with it. As long as you got a good rough and clean spot for the jb weld to adhere to,im willing to bet itll be ok.
    current ride--a derelict shopping cart
    Happy terrapin with koozies!!
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/17 19:27:13 (permalink)
    I with Bcom!!!! Let it ride!!!!
    JOE G
    Dirt Monster
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/17 20:32:14 (permalink)
    I scuffed it up with a sanding disc and a stone on a dremel, I guess we will see.
    Is Permatex Ultra copper  RTV ok to use on a new factory gasket?
    Or would Hondabond 4 or Yamabond 4 be better?
    2002 GSX-R 750.
    2002 HONDA ACCORD.
    bcom
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/17 21:05:54 (permalink)
    I can count to potato
    post edited by bcom - 2016/11/18 18:28:14
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/17 22:08:58 (permalink)
    Hondabond or yamabond. It doesn't break apart as easy as other sealants. When it dries its like a rubber band. So no worries of any little pieces that get squeezed out breaking off inside the case. I atv shops have a heart attack when they see the other sealants used.
    Theblue300
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/18 07:06:04 (permalink)
    Permatex is a big no no on any engine imo. And this is why especially on these smaller ones. And this was only about 3/4 of it there was more before i pulled some off and even more before i peeled it off the case covers.
    95 Honda 300 Fourtrax-big red rear, 2 inch snorkel, 6 inch lift, 8 inch stretch, 3 inch body lift, 32 silverbacks, locker, M4 motorcycle exhaust, 424, 54% reduction, EPI Economy,
    380, 450 clutch, 350D clutch cover all waiting to be installed.
    88 honda 300 frame- 350d motor with a 69% reduction, small lift and 31 wides, dual 2.5'' glasspacks, 3.75'' body lift, locker, 450 foreman clutch still dont run
    98 honda 300 4x4- all stock for now might get 450 gears and a 317 someday.
    JOE G
    Dirt Monster
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/18 20:23:43 (permalink)
    So you guys suggest Yamabond 4 or Hondabond HT instead of permatex.
    2002 GSX-R 750.
    2002 HONDA ACCORD.
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/18 22:03:53 (permalink)
    THAT'S A BIG YES!!!!!!!!!!
    JOE G
    Dirt Monster
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/28 07:31:06 (permalink)
    Its all back together and it seems to be leak free and the JB Wled seems to be holding so we will see. I used just a little bit of the Permatex Copper spray.
    2002 GSX-R 750.
    2002 HONDA ACCORD.
    Re: 08 Raptor 250 JB weld Stator cover and metal shavings question 2016/11/28 21:44:30 (permalink)
    I hope it all holds for you.
