Locked08 Honda rancher 420 problems
Boss Of The Stix
Mud Slinger
2013/08/01 22:42:44 (permalink)
I have an 08 Honda rancher 420 2x4 that isn't running at the moment, the bike isn't getting spark, I changed the spark plug and when I took the spark plug out and tried to run it there was no spark, any suggestions to what may be the problem with my bike. I think it may be the coil but I'm no expert mechanic.
09 Grizzly 550
30in silverbacks on stocks
Stick stoppers and skid plates
Custom snorkel
Custom audiopipe
Odi grips
Angel eyes
Project bike
08 rhino 450
12 Replies Related Threads
    Machinist
    Re:08 Honda rancher 420 problems 2013/08/01 23:01:10 (permalink)
    Coils on Honda's aren't known to go out, normally it's something else but not always. You did rule out the simple checks such as kill switch position and main fuses? Also was the bike running or did you buy it not running as a project?
    08' Rincon~Rubber Down Customs Lift~HL Lift Springs Pc'd Black~HL Fender Kit~HL Skid Package~29.5x10 Laws~SS 112 Chrome~Big Red Gear Reduction ~UNI~Warn 2500LB~HL Gel Grips~2'' I.D. Snorkel~Custom Shift Handle~Atv-Guru Bumper~NGK Plug Boot~10K Hid's~
    Past Rides:
    1979 & 1980 ATC 70
    1980 ATC 110
    2001 Honda 450ES
    2000 Bayou 220
    1994 Honda 300 4x4
    Boss Of The Stix
    Mud Slinger
    Re:08 Honda rancher 420 problems 2013/08/01 23:03:38 (permalink)
    Yup, checked kill switch and changed all fuses, I had it running about a month again then it just died and I haven't been able to get it running since
    09 Grizzly 550
    Custom snorkel
    Custom audiopipe
    Odi grips
    Angel eyes
    Project bike
    08 rhino 450
    shady1423
    Re:08 Honda rancher 420 problems 2013/08/01 23:08:31 (permalink)
    I had this same problem after a rebuild. It was my timing key. May have that problem. If it jus all of a sudden quick an wont crank back
    2013 500 foreman es
    2" lift in front
    30" backs
    2" snorkel
    14" diesel rims
    Hmf exhaust
    axle paddle
    Hondaowner994
    Re:08 Honda rancher 420 problems 2013/08/01 23:10:52 (permalink)
    I would inspect your CDI for any bulges or cracks, also if it has a burnt electrical smell that could be your problem. If it is indeed your CDI check to make sure your voltage regulator is charging at normal voltage. A bad voltage regulator can cause the CDI to burn up because the it can't handle the extra voltage that would be coming through.
     x-Sam's Towing-x
    "Just try and follow me, see how well that works out for you"
    If you don't have time to do it right, then you must have time to do it over.
    "Ol' Red"
    -1996 Honda Fourtrax 300 4x4-
    -27x10 Vamps Up Front-
    -26x12 Vamps In The Back
    -UNI Filter-
    -Cup Holder-
    -2000LB Winch-
    -2" Lift-
    -1" Spring Spacers-
    -Fully Snorkeled-
    -Rear Brake Delete-
    -Ammo Cans-
    -Front Brake Delete-
    -Audio tube-
    -EBC Dirt Racer Clutch Kit-
    -Extra Lights-
    -Bored .40 Over-
    Boss Of The Stix
    Mud Slinger
    Re:08 Honda rancher 420 problems 2013/08/01 23:19:17 (permalink)
    Shady1423
    Where is the timing key located
    Hondaowner994
    Imma check the cdi and voltage regulator tomorrow, and if the cdi is bad what else would be broken other than it nit getting spark
    09 Grizzly 550
    Custom snorkel
    Custom audiopipe
    Odi grips
    Angel eyes
    Project bike
    08 rhino 450
    toodeep
    Re:08 Honda rancher 420 problems 2013/08/01 23:30:18 (permalink)
    Does the fuel pump run when you turn on the key? Do you have a shop manual and multi meter to do some testing? Has it been ran in the water a lot (plans for the snorkel)?
    07 TRX475FM                     09 TRX420FA
                  95 TRX300FW                          88 TRX300
    Boss Of The Stix
    Mud Slinger
    Re:08 Honda rancher 420 problems 2013/08/01 23:37:26 (permalink)
    Fuel pump works fine, never had it in deep water yet, I planned it to be a water bike after I bought my grizzly but it quit running
    09 Grizzly 550
    Custom snorkel
    Custom audiopipe
    Odi grips
    Angel eyes
    Project bike
    08 rhino 450
    Machinist
    Re:08 Honda rancher 420 problems 2013/08/02 06:23:01 (permalink)
    I would get an OHms meter and a manual and start testing your electrical components to help locate the problem. Look over your wiring harness just to make sure nothing could of possibly chewed on it and look for signs of heat damage.
    Past Rides:
    1979 & 1980 ATC 70
    1980 ATC 110
    2001 Honda 450ES
    2000 Bayou 220
    1994 Honda 300 4x4
    shady1423
    Re:08 Honda rancher 420 problems 2013/08/02 08:48:18 (permalink)
    It's inside the rear case. It hold your flywheel in the right spot on the crank. If it sheered an move any it won't run right or at all
    2013 500 foreman es
    2" lift in front
    30" backs
    2" snorkel
    14" diesel rims
    Hmf exhaust
    axle paddle
    toodeep
    Re:08 Honda rancher 420 problems 2013/08/02 09:04:52 (permalink)
    I would start with taking all the connectors apart in the bucket behind the battery. I get a lot of problems from that area from either water or rodents. If those are good I would do a peak voltage test on the CKP sensor (pulse generator). Also check the plug on the regulator, sometimes it will short enough to cause a "no fire" situation.
    rmpenton
    Re:08 Honda rancher 420 problems 2013/08/02 09:27:01 (permalink)
    Will a bad rectifier cause a no spark like it will on a foreman 450
    2011 rancher at
    28" outlaws with 29.5 lug height
    12" sti hd3's
    Sra gr.
    Highlifter signature series lift
    Viper 4500 elite series winch
    toodeep
    Re:08 Honda rancher 420 problems 2013/08/02 10:17:25 (permalink)
    I haven't had many problems with them on the 420's but yes it's possible.
