Locked08 Brute force in limp mode and will not reset need help!
JBrazell
2010/03/16 17:03:08 (permalink)
I have a 08 brute the belt light came on and the bike went into limp mode at about 30 mph now i cannot get the system to reset if anyone has had this problem or has any info on it please let me know thank you.
2008 red brute force 10inch catvos lift, 30" mudlights, Clutch kit, Snorkles
2005 Arctic Cat 500 2in lift, 29.5 laws, 2.5in spacers, rad. Relocated, snorkled
2001 Honda Foreman
9 Replies Related Threads
    bigblackrancher
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/16 17:20:47 (permalink)
    1. Remove seat, unplug black and gray 4-pin connectors.
    2. Swap plugs, gray to black and black to gray.
    3. Turn on ignition switch, belt light should be flashing quickly.
    4. Disconnect 2-pin belt switch above torque converter cover, belt light should be flashing slowly.
    5. Let flash for at least 5 seconds.
    6. Turn off ignition switch.
    7. Reconnect 4-pin connectors black to black and gray to gray, reconnect 2-pin belt switch.
    8. Turn on ignition switch to confirm belt light is out.
      -10' blue brute -sold
    -2012 rzr le silver
    28"mudlites
    2" racertech
    looney tunes duals
    top, windsheild
    -05 brute force 750
    JBrazell
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/16 18:02:07 (permalink)
    Thanks for the info i was unplugging the biger wire on top of the cover..........
    2001 Honda Foreman
    alljackdup2
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/16 18:23:37 (permalink)
    Just curious, but what makes the Brute go into limp mode?  I just bought my Brute a month ago and need to know what to look for.
    Thanks,
    Scooter
    '08 Brute
    Snork'd by AllJackdUp, Ocala, FL
    Map'd
    2"lift
    29.5 Laws on 12" Nuke's
    HL Rad relocated
    Grilla Axs
    HMF Penland
    High Comp Pistons
    '05 Griz
    Snork'd
    Clutch'd
    Program'd
    Rad on top
    2"lift
    28" SBack's on 312's
    Grilla Axs
    Swamp Series HMF
    crom a zone
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/16 19:39:37 (permalink)
    they say at 100 hours it will for seirvrd but i am at 117 and never came on guess i got lucky
    Resquedude
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/17 00:48:47 (permalink)
    belt light comes on every 100 hours to try and force you to check belt.. limp mode is different
    2007 Black Brute Force 750
    lifted  -  Swamplites/SS212's
    Carb stuff - Clutch stuff - CDI stuff
    Submarine Snorkel
    4000lb Viper Winch
    HMF Swamp Series
    Pro X tie Rods
    "That there's an ATV Clark"
    bustamove
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/17 01:45:24 (permalink)
    yeah there is slow blink belt light then fast.... anything fast is NOT GOOD lol
    08 BruteForce 750. 26 big horns 2.0, Ricochet skids, XT2500 winch, 2inch lift, no sway bar, blue gauge lighting, Temp gauge. oil pressure gauge. piaa lighting, engine snorkel. HID's, custom rock sliders, custom flat pack rack, twin air, big guns full exhaust, fuel controller, asr tie rods, all joints grease able, back up light.
    bayou bogger
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/17 06:58:56 (permalink)
    JBrazell
    I just want to know what your CV boots look like with a 10" lift at 30 MPH!!!
    09 RZR LE
    3" CATVOS Lift
    30" Skinny S-Backs
    14" MSA Torks
    HL Floor Board Kit
    HL 1" Spacers
    Snorks
    Twin Speaker Tubes
    Roof, Bumpers and Rock Sliders
    S Fender Flares
    bigblackrancher
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/17 18:03:01 (permalink)
    yea me too^
    -2012 rzr le silver
    28"mudlites
    2" racertech
    looney tunes duals
    top, windsheild
    -05 brute force 750
    alljackdup2
    Re:08 Brute force in limp mode and will not reset need help! 2010/03/17 22:15:01 (permalink)
    Uh oh.  I am at 90 hours now and will certainly go over 100 hours while at Mud Nat's.  Good thing I am going with my mechanic!
    Thanks everyone for your help...
    '08 Brute
    Map'd
    2"lift
    HL Rad relocated
    Grilla Axs
    HMF Penland
    High Comp Pistons
    '05 Griz
    Snork'd
    Clutch'd
    Program'd
    Rad on top
    2"lift
    Grilla Axs
    Swamp Series HMF
