Locked07 Rancher 400 AT Shifting issues
txstrphyhntr25
Dirt Monster
2009/12/15 19:23:19 (permalink)
My brother is having problems with his Rancher shifting from forward to reverse and i need some ideas of what it could be. It will drive perfectly normal in all 5 gears and it will even drive normally in reverse. The problem is you have to tap on the side of the transmission to get it to go into reverse and the same to get it to go back into drive. We disconnected the cable and checked it and it works normally. The problem feels like something in the transmission is in a bind. We're a little worried about cracking the transmission open. Any suggestions would be appreciated.
2007 Honda Rancher 420 4x4 ES
28" Outlaws
or 26" Mudlites
Warn Winch
6 Replies Related Threads
    RancherAT20
    Re:07 Rancher 400 AT Shifting issues 2009/12/15 19:25:54 (permalink)
    is this in automatic or es
    98 Honda Fourtrax 300 4x4
    27" ITP Mudlites
    ITP Rims
    3" custom lift kit
     Snorkel
    K&N Air Filter
    SOON TO COME
    Disc Front Brakes
    LAWS?
    txstrphyhntr25
    Dirt Monster
    Re:07 Rancher 400 AT Shifting issues 2009/12/15 19:41:59 (permalink)
    It will drive fine in both ES and AT. Just have problems shifting with the lever.
    28" Outlaws
    or 26" Mudlites
    Warn Winch
    toodeep
    Re:07 Rancher 400 AT Shifting issues 2009/12/15 19:46:13 (permalink)
    It could be a bent shift fork shaft or corrosion on it where it goes through the case making it stick.
    07 TRX475FM                     09 TRX420FA
                  95 TRX300FW                          88 TRX300
    Honda Mechanic
    Re:07 Rancher 400 AT Shifting issues 2009/12/16 05:40:15 (permalink)
    We get quite a few in that are seized or starting to seize .. They will corrode/seize where the steel shaft passes thru the aluminum case .. Most we just dis-assemble and clean up with emery cloth .. This customer wanted new parts ..
    txstrphyhntr25
    Dirt Monster
    Re:07 Rancher 400 AT Shifting issues 2009/12/16 09:28:56 (permalink)
    Thanks for the help guys. I'm going to try this when I get off work.
    28" Outlaws
    or 26" Mudlites
    Warn Winch
    txstrphyhntr25
    Dirt Monster
    Re:07 Rancher 400 AT Shifting issues 2009/12/17 14:21:39 (permalink)
    This was the problem and it was a very easy fix. Ours was not nearly as dirty as the one in the photo but it was frozen solid. Had to heat up the aluminum and use a press to get the shaft out, but after a little cleaning and some grease it works fine. Thanks again for all the help and the photos.
    28" Outlaws
    or 26" Mudlites
    Warn Winch
