Hot!'06 Foreman 4x4 stripped differential cap
camoman33935
2017/03/12 13:48:13 (permalink)
Long story short I have let my 2006 Honda Foreman 4x4 sit for about a year without maintenance. Stupid on my part yes I know but work keeps me really busy.
I am in the process of changing all of the fluids (motor and front and rear differentials). While attempting to remove the full cap on the front differential with the appropriate sized socket, the aluminum head of the fill cap began to strip. So now I am in limbo as to what I can do to get this thing off. It feels as if ithe threads are seized.
Any suggestions on how to unseize and remove the fill cap?
7 Replies Related Threads
    toodeep
    2017/03/12 16:55:52 (permalink)
    Tap on it a couple times with a hammer and use a good 6 point socket on it.
    Sent from my SM-G935V using Tapatalk
    camoman33935
    Re: 2017/03/12 22:11:58 (permalink)
    I'll try this again. The only issue is that when it started to strip the socket for that mm now spins freely on it. I may have to file down to get a smaller mm socket to fit.
    Would heat help at all?
    2006 Honda Foreman 4X4
    29.5 Skinny Laws
    Xtreme Gear Reduction
    Triangle ATV Snorkel
    HMF Utility Series
    K&N Airfilter w/ prefilter
    Dynojet
    toodeep
    2017/03/12 22:33:55 (permalink)
    I've removed a lot of them with rounded heads using a good 6 point 17mm impact socket. If it's too rounded you might get an standard socket tapped on enough to work. Heating it will just make it expand so probably won't help.
    Re: 2017/03/13 06:57:03 (permalink)
    Just get you a good chisel and catch the edge of the cap and start tapping. It will come right off. Wouldn't be the first time I had to do that. Or get a big pair of channel locks. Just think about it and I'm sure you will get it off.
    Jeepwm69
    Re: 2017/03/13 10:23:13 (permalink)
    Tap on it with a hammer to break the threads loose, then put some vice grips on it to get it off.
    Welder304
    Re: 2017/03/18 07:38:13 (permalink)
    Those caps break all the the time and tapping aluminum with hammer will just get to break sooner time to order new caps
    Re: 2017/03/18 09:18:03 (permalink)
    He already broke it so a new cap was already in his future!!!
