Locked05 yamaha bruin engine problem....
Guest
  • Status: online
2007/08/03 22:59:08 (permalink)
Friend has a 05 bruin....he said the motor has a bbk
He said when he goes in reverse it sputters and backfires
suggestions on the problem?
08 brute 650
28 swamplites on rattlesnakes
highliter springs
2in lift
dynatek cdi
almond secondary
6 Replies Related Threads
    mud_dog450
    RE: 05 yamaha bruin engine problem.... 2007/08/03 23:05:55 (permalink)
    It has a reverse rev-limiter.  Is he aware of this?
    The Mud Brothers
    Goin' Deep Since 2004!
    02 Grizz 660...umm...7??
    Everything Snorkeled
    Clutch Work
    29.5 Laws on Vision Buckshots
    Muddin Videos
    Guest
    • Status: online
    RE: 05 yamaha bruin engine problem.... 2007/08/03 23:27:00 (permalink)
    I dont think that it
    he says maybe he needs a bigger jet for the bbk?[&:]
    08 brute 650
    highliter springs
    2in lift
    dynatek cdi
    almond secondary
    mud_dog450
    RE: 05 yamaha bruin engine problem.... 2007/08/03 23:33:16 (permalink)
    If he is not having the problem in forward gears, then most likely it is his reverse rev-limiter kicking in.  We need alittle more details.
    Does the bike speed up in reverse then just seem to hit this problem?
    The Mud Brothers
    Clutch Work
    Muddin Videos
    gatorlover
    RE: 05 yamaha bruin engine problem.... 2007/08/04 20:58:16 (permalink)
    there is 2 sputterings i have had with my bruin.  one was the rev-limiter in reverse and the there was water in the gas, but if he is not having trouble in forewards than its not water in the gas.
    When the mud is deep and the hills are steep, LET R EAT
    350 Bruin 4X4
    26" Gators
    2500 lbs. Chicago winch (for pullin my buds out)
    Power madd hand guards
    WARN snow blade
    Custom Bent front rack...LOL
    Angus
    RE: 05 yamaha bruin engine problem.... 2007/08/05 08:36:50 (permalink)
    The rev. limiter is easy to bypass.  If he's never done it then that's the problem.
    Check www.grizzhopper.com
    It's the same as the older Grizzlys except there is no bullet connector.  Just tap into and ground the green/white wire.
    • 2005 Yamaha Kodiak 450
    • 2005 Toyota Tacoma DC SR5
    JS
    RE: 05 yamaha bruin engine problem.... 2007/08/05 10:13:34 (permalink)
    hmmmmmmmmmmm..............................[&:]
    2005 Yamaha Rhino 660 4x4
    2014 RAM 2500 4x4 6.7L CUMMINS DIESEL
    2010 Sea-Doo Challenger 230SE 430 HP Supercharged
