Hot!03 vinson 500 manual shift
Mike420
2021/03/10 23:59:59 (permalink)
I got a 03 vinson 500 an when am driving an shift up to 3 the indicator light that tell me am in 3 on the cluster is just blank an then it seem like it hit rev limiter really quick but when I shift to 4 it showes up on the cluster but 5 don't N it falls flat on its face then it will pick by up then fall right back anyone know what making it do that plz help
Sent from my SM-G960U using Tapatalk
2 Replies Related Threads
    Re: 03 vinson 500 manual shift 2021/03/11 22:58:51 (permalink)
    Ok check the wire harness going to the display. The loom is tight and pulls on the wires and cause them rub a hole through the insulation and possibly break them. Also that's a carbureted motor so falling on its face is something fuel related. Clean your carb and check your air fuel mixture.
    Mike420
    Re: 03 vinson 500 manual shift 2021/03/12 01:38:29 (permalink)
    Ok I will check but its only fall on it face when that happen with the gear indicator when it dont show up it does that but if they show up it runs good as **** can't bet it r they some kind of sensor that could be causing it I think the clutches need adjusted to I can pull up on the shifter an it stall will go but I will check that an let ya know
